SuperHatch »
https://forums.nicoclub.com/superhatch-u50790.html
Wed Jan 16, 2008 3:16 am
The Q45 bellhousing will bolt to the KA auto transmission. The KA auto (RE4R01A) and the VH auto (RE4R03A) are the same size physically, but the VH auto has more clutch packs inside to allow it to hold more torque. The VH auto and the Z32 TT auto are the same transmission, so there would be no benefit in swapping them.
If you install the VH auto, you can use the KA's transmission mount and crossmember. However, it will locate the engine about 1" further forwards than the KA would be, because the bellhousing on the VH is longer {engine to transmission) than the KA bell. My suggestion as a temporary fix, is to use the middle bolt on the transmission crossmember (there are 3 on each side) in the rear hole on the car, this will slide the transmission and engine back about 1" which will locate the engine nicely, then just fab up some motor mounts. You will need to shorten the shift linkage as well, and the bellhousing will interfere will the firewall in one spot on the bottom drivers side. (nothing a bfh can't fix)
