S14 SR20DET Motorset
Mafioso
What else needs to be purchased to complete the swap?
Motor, Trans, Un-cut harness, Maf, ECU, and Igniter Chip.
I know I'll need to buy a Radiator.. Intercooler.. I assume a BOV. I think that's it beyond the normal fluids and maintenance items.
highmilehatch
As for a cooling setup, I'd do the stock S14 SR radiator (stock or upgraded), stock clutch fan, electric fan, and hoses.
I'm sure people will try to tell you otherwise, but I've had more success with with the above setup than ditching the stock clutch/electric fans and running dual electric fans with no shroud. The stock SR shroud/clutch fan WORKS WELL. The S14 KA electric fan will bolt right up to a S14 SR radiator.
Don't forget the hotpipe, which usually is not included in the FMIC kits.
I like the HKS SSQV bov on MAF cars.
Don't forget upgraded fuel pump and Z32 filter.
What chassis is this going into?
Mafioso
S14 Kouki. Car already has a Walbro 255, Z32 Fuel Filter, Blitz Nur Spec exhaust, Tein HE's, 5 lug (base to SE)..
highmilehatch
Nice. Sounds like a prime candidate. You'll be happy you went with a S14 SR in your chassis.
Mafioso
LOL Especially since it won't start right now. :D lol
highmilehatch wrote:Nice. Sounds like a prime candidate. You'll be happy you went with a S14 SR in your chassis.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
this should give you a good idea at to what you will need. If you search a little bit there is tons of info about this.
http://www.heavythrottle.com/
Mafioso
I promise I attempted to search but was unable to locate information. Probably using the wrong search terms.
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
It wouldn't be a bad idea to install a new clutch and flywheel, or have the stock flywheel re-surfaced, before you install the engine in the car. Also a boost gauge wouldn't hurt.
Try searching for s14 swap, and limiting the search to the sr20 rwd forum. Do 1 search in recent content, and 1 for archived content.
