S14 SR turbo outlet needed (90*)
92vert240
Car: S13 hatch S14SR20 stock record-12.35 at 110, 87 t-type 10.69 at 132. hatch daily.
To put an s14 SR into an s13 i found the intercooler plumbing is all haywire. So, i need the turbo outlet that is 90* (facing up) rather than on a 45* angle towards the front of the car. Where can i find this? Or does ayonehave it used? Is it the same as the s13 ? If someone has the other pipe from the intercooler hot side to the hot pipe (turbo outlet) i can use that too. If not just the outlet will do. heres a pic of what im taking about. This is the 45* one.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Its not the elbo that is different, it is the compressor housing. You will need to get a hotpipe for an S14, or modify your current cold pipe, for this to work.
Kalypso
take it to a muffler shop and have them bend a pipe for you.
wzntha
92vert240
wzntha wrote:so you're saying you replaced your old s13 turbo with a turbo from an s14, right? if so, you should get this:
http://phase2motorsports.store....html
you can reuse the old elbows with these adapters.
No i have an s14 sr in an s13. I read on another forum that greddy makes the 90* outlet.
I have the kit for the s14 so my cold pipe is good. Its the hot side thats all screwed up.
Hijacker
Car: '92 240sx Convertible
'94 F-150
You can pick up the adapters from an eBay store for about $50. Good quality aluminum. You will need a second set of gaskets though.
wzntha
92vert240
I was trying to avoid fabrication like i am a customed to on my GN but when I looked at what needed to be done and what i was given, it was very simple. I will have pics and a full write up on "how to" Tomorrow. Only takes about 5 minutes to make this work.
