Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Nov 29, 2007 11:56 am
The backfire is probably due to being enriched.
I suggest getting a set of NGK coppers or Iridiums. I like to use Iridium p/n BKR6IEX-11. If you've turned the boost up, you can use the 6 heat range or the 7 heat range. It really depends on your motor. My motor likes 6s better at 13 psi.
The TPS is the Throttle Position Sensor. It's a black box attached opposite the throttle pully on the throttle body. It sends a signal to the ecu that says "throttle is opened this much" If the signal is off, the ecu's fuel maps will be off. When you set the idle and timing, you need to unplug the TPS as the idle will change a bit and the timing will advance/retard on its own. Removing the TPS will result in the ECU defaulting to a base map that doesn't fine adjust the idle and timing.
Expect richness with venting. I'm 99% certain the cause is that for you. The ECU meters air as it flows at the entrance. It's already sent fuel to the cylinder for the metered air. So when you vent, that fuel is still on its way, but the air in the system just dropped so you end up with more fuel than air. It's why a lot of cars stall when they're stopping and venting.
The only way to vent atmo is a blowthrough maf setup or a map sensor.
