S14 SR into an S14
deltr
I've scoured the net for specific info on this swap and can't find much. Does anyone have some tips on completing a S14 SR swap into a 95'? Do I need to mess with the heater hoses? Remove heat shields to let the steering column clear the turbine? Do I need to extend the engine harness in areas?
An appropriate link to a S14 into an S14 thread/guide would work greatly. My clip will be here in 2 days and I need to be prepared.
Thanks!
fast_s13
stock heater hoses work with a little trimming....everything else bolts up... as far as wiring goes search for topics created by me
fast_s13
here i'll help you out here is the link zerothread?id=219319
sbanzer123
Car: 95 s14
the swap is cake. no removal of heatshields. like fast s13 said just trim the hoses and they will fit. the wiring is the hardest part.
kouki_240
Car: 97 240
just the thread i was lookin for. thanks
xdabsx
Car: 96 240sx/92 240sx coupe/94 240sx vert/95 240sx/93 240sx hatch
i was a noob when i did it.it was very easy everything bolts right up.wiring is the hardest part
