bmx269 »
https://forums.nicoclub.com/bmx269-u100483.html
Fri Jul 04, 2008 5:46 am
I had an issue with the way I wired the Nissan to Toyota wires. The way it was wired was causing some weird back feed of power through the ECU from somewhere, which cause 2 ecu's to burn. The that burned was Pin 45, IGN power. The 2 diodes popped, which happened when I stalled the car, both times. After some figuring, I figured that the alternator to car wiring was one of the problem circuit s. As you may already know, a diode is like a 1 way valve for power. Well it seemed that the way the stock corolla wiring for the alt circuit was allowing power to flow for a second after the car was off on a few wires. Well that was the cause. I decided to wire the car "race car" style, as it is pretty much a track car. So I separated the car and engine like described below. This is how my whole car is powered and controlled, and after testing, it works way better, and is easier to diagnose.
(12v +)Alternator -> Battery -> Kill Switch ->
-> Kill Switch -> Power Distribution Block -> -> Power Distribution Block -> Fuel Pump Relay Power-> Power Distribution Block -> Fan Relay Power-> Power Distribution Block -> Starter Main Power-> Power Distribution Block -> Moroso 6 Switch Panel with 20A Breakers ->
-> Moroso 6 Switch -> Starter Trigger Power-> Moroso 6 Switch -> IGN Power ->-> Moroso 6 Switch -> Fuel Pump Relay Trigger-> Moroso 6 Switch -> Acc Power ->-> Moroso 6 Switch -> Fan Relay Trigger-> Moroso 6 Switch -> Lights (for gauges)
->IGN Power -> All ECU Powers, and Power to Alternator regulator, all fused individually via 12 circuit fused power distribution block
->Acc Power -> All Gauge Powers, and O2 Sensor Power all fused individually via 8 circuit fused power distribution block
-> Kill Switch -> Toyota Power for Headlights, Brake Lights, Stereo, Etc
(Negative/Ground)Battery -> Ground Distribution Block -> Chassis
->Ground Distribution Block -> ALL GOUNDS (Engine Block, ECU, O2, Switches, Relays, Gauges)
That basically covers the way I wired it up. I will take some pics this weekend before the drift event on Sunday. I think that the way it is wired now makes a lot of redundant fusing, but that will help me diagnose any circuit if there is a problem.
-Trent
