s14/s15 CAS
lilpiton
Car: 92 hatch
So Some of you might know that I having some issues with my s15 sr.
And my buddy (which has an s14 sr) and I would want to try his s14 CAS on my s15 but we dont want to it, if it will not work. So if andone knows aynything about that please share and help me fix my car.
Thanks Tom...
lilpiton
Car: 92 hatch
nothing!!
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Not many people run the S15 SR man. I moved your thread into here hoping SOMEONE would chime in, but so far, no good. :( I'll do some looking tonight, since my internet seems to be working correctly again.
I WILL have an answer for you by tomorrow evening. Just bare with me. (Ask some of the guys in this forum if there is anything I haven't found yet that I've looked for.;) )
PyR0NiAk
http://www.240sxmotoring.com/oemcransecfo.html
240sxmotoring has them all listed as the same part. Seems they might all be interchangeable. It won't hurt anything to try his, and it takes less than 20 minutes to swap one out.
lilpiton
Car: 92 hatch
yea i seen you help out alot of ppl so far. And Im one of them lol.
I seen the 240sxmotoring thing and thats what I thought, thanks for the help bro.
I took both my s15 and my buddys s14a ECU wiring diagram and looks all the same with the CAS, so will be swapping them on thursday since its my day off.
Thanks Tom.
PyR0NiAk
Just got confirmation for you. S13, S14, and S15 all use the same CAS. ;)
lilpiton
Car: 92 hatch
sweet !! thanks again
lilpiton
Car: 92 hatch
ok, so we swapped out the cas with the s14 one and still nothing.
So its not the CAS.
PyR0NiAk
Do you have a thread with your issue? If so, and I'm already in it attempting to help you, I'm sorry but I don't remember, so link me to it. I just want to see what you've done and what you haven't. When you swapped the CAS, did you actually take the valve cover off and reset your cam timing?
lilpiton
Car: 92 hatch
help-my-start-my-sr-t492621.html
yea i took of the valve cover and what you mean be reseting my timing. like take off the chain, no.
I just set it to TDC and did it like that.
PyR0NiAk
You'll need a 24mm socket.
Take socket and rotate the exhaust cam until your crank pulley notch. 2nd one from the left is lined up with the pin.
Then check and see if your intake cam's key is at 10 o'clock and your exhaust cam's key is at 12 o'clock.
If not, do it one more time. It reaches this point once per every 2 times you turn it over to that position.
Once you're there, look at the notches on the cams, and make sure you have 9 links between them. That's 11 if you're including the links right above the notches, as well. If so, your mechanical timing is dead-on and you're now at TDC on cylinder #1. Reinstall your CAS. You'll line up 1 dot and then once inserted it'll rotate around to the next dot. Your CAS should be dead centered on the bolts with the dot lined up.
Here's a link with images from a NICO Sponsor. http://www.frsport.com/How-To-Set-Crank ... _t_25.html
Note: You don't need to have the colored links on the chain line up. Those are for the initial install of the chain.
lilpiton
Car: 92 hatch
the timing is dead on with the marks i didnt really check the way you said in the paragraph above but I know its right on.
PyR0NiAk
I definitely recommend you do it the way I just posted. It's a 20 minute job...
lilpiton
Car: 92 hatch
but how could it be off if it was fine before i took off the valve cover, and i didnt mess with anything like that?
PyR0NiAk
When you installed the other CAS, you needed to do this to set the timing correctly with the CAS, so if you didn't do this, your timing is now off, and your CAS may have very well been the issue.
lilpiton
Car: 92 hatch
just got in from the garage checking the timing the way you said and its right on the money.
PyR0NiAk
I'm going to have to go with what White Comet said in your other thread, then..
