CRyan »
https://forums.nicoclub.com/cryan-u23575.html
Tue Jun 08, 2010 2:28 pm
Have you tested your timing, just for the "its not that" motive? I would do it just in SOME WAY something could have been accidentally tampered with.
Also, if your pulling weak spark, ohm your coilpacks, they should have like 1.3 ohms, voltage should be 12.6.
What else. Hmmm - Check tps, knock sensor, engine coolant temp sensor. Make sure your ground is to the chassis, and then jumps to negative on your battery.
Have you checked the springs in your coil packs? Take a wire brush to them to get some new metal on the plugs.
Thats all I can think of man, I hope it helps - I hate to see a downed SR, especially because I have to look at one every day.
