S14 rear quarter window area-Thinking of putting a speaker there-Advice needed
Chaotic_Warlord
Car: Black 5 speed Swapped 1995 240sx
Ok so I've been pondering for a while about that space underneath the rear quarter window, and how that would be the perfect place to conceal a small to medium sized mid range speaker so that I can get more bass into my car without having to do a sub install. My questions are:
Would it be at all possible with very minor modification?
Has it been done?
What size speaker do you think I could get into that space?
I have a small amp that I can mount in a covert location but don't know if it will work since it's old as hell but it's never been used. I was thinking of maybe getting a 6.5" or maybe if possibly an 8" on each side.
Any help would be great. I've done a search but can't find any information.
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
IMO that is not an ideal location for a mid range speaker of any worthwhile size. An 8" diameter speaker would be very difficult to fit into that location...6.5" maybe, but I believe both would definitely require some type of custom trim ring to compensate for both the contour of the panel and allow for the depth of the speaker. Have you considered a 6.5" component system with the woofer located in the front door as well as a full range with plenty of power in the rear location? To answer your question- it depends on what you would consider 'minor' modification and, yes, I am sure something similar has been done in the past. I would suggest asking Broadfield since he is the master of all that is sound Just my .02. Good luck.
gregfarz78
Car: 04 Honda S2000
97 Nissan Hardbody King Cab 4x4
09 Nissan Altima Coupe 3.5L
I have to agree its going to sound like poop in that location a bassy speaker there is just going to rattle the plastic trim and/or exterior of the car. Personally I would stick with nice components in the front doors and get a compact 8"sub then fiberglass a nice small custom enclosure in the corner of the trunk, it won't add a lot of weight or take up a lot of room.
pcurr22
Car: 1998 240SX
i found this a while back. dunno if it will help
http://www.240sx.org/links/ins....html
Chaotic_Warlord
pcurr22 wrote:i found this a while back. dunno if it will help
Thanks dude that's basically what I was looking for. If I dynamat the whole area and fill in the excess space I don't see why it would rattle that much or sound like poo.
I just want to get a little more sound out of my car to cover the loudness of my exhaust and trans.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Its been done. There was a guy locally with 6"x9"s mounted into that spot. It sounded really good, and I thought about copying the setup for a while, then I remembered I have 1000 other things that need attention before I can start seriously mucking about with my audio.
pcurr22
Car: 1998 240SX
anytime man. i was gonna do it but i dont have anywhere to work right now. maybe over the summer.
Chaotic_Warlord
6x9's in that location would actually be really good, probably better than a sub. I don't want to advertise that I have non oem stereo components in my car and subs would do that, where as 6x9's or even 6.5" mid ranges would just increase the volume and give me more a true surround sound sound stage.
pcurr22
Car: 1998 240SX
any updates?
Chaotic_Warlord
pcurr22 wrote:any updates?
Nope, completely forgot about it actually, I'll look into it further when I get around to removing the back seat and putting it a cage and interior chassis bar.
