s14 rear camber adjustment
mksue3240sx
Car: 240sx
Lowered my car now my rear camber is out . Saw some various suspension arm kits on ebay, just wondering what methods any one has used to correct this problem.
ThuG LyFe
Car: 95 S14
you need the rear upper control arms (RUCAs) and probably adjustable toe arms or w/e it's called as well for caster was it?
mksue3240sx
Car: 240sx
It has a couple of upper arms, do they both need to be adjustable? I think the toe is already adjustable.
Skilz10179
Car: 98 240SX
For camber adjustment you need adjustable rear upper control arms.I'd steer clear of the ebay parts unless you find known name brand parts there. A lot of people on here seem to rave about SPL parts.
I'm looking for some adjustable RUCA's too but i'm still unsure which ones to buy.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
There is a small amount of camber adjustment from the factory in the form of an eccentric bolt.
If the cam bolt cant get you enough camber adjustment, I would suggest getting some adjustable RUCA from SPL.
