YR240 »
https://forums.nicoclub.com/yr240-u59227.html
Thu Mar 05, 2009 5:51 pm
I have typed this in the Google search at least a 100 times and the only thing I have seen is the cheap looking eBay alteza knock offs. So, enough looking I am going to do this myself. I have 200 Bright White LEDS, an Extra set of Tails from the U-Pull-It, I am ready to do this!
First things First: Extra set of taillights. (why have just one when you can have two)
Now time to cook the lights, literally, throw those things in the oven at about 200 Degrees and wait 10 minuets. Once warm take a screw driver and start removing the lenses from the assemblies from the outside in. Sorry I don't have any pictures of this step yet.
Once done you have this Elmo was helping in this step.
Once apart I took a few LEDS and shined them at the lenses to get a feel of how it would look. I hated it. The lenses are not set up for LED in any way, but that is okay, nothing a little Sand paper cant fix. I took 80 grit Green sandpaper to the inside of the lenses to get the molded divots off. It will take some work, but it is turning out real nice. I will polish them after sanding them down with 200, 400, 600 1000wet. Divots
Sanded Divots
Once done the lenses will be tinted Red and completely see through.
I like simple, so I think What I will do is use the clear diffusers to hold the LEDS into place by Drilling or Laser Cutting the LED pattern into them, These are the clear diffusers:
This is the first pattern I have Started for the Lights, any suggestions in this area are welcome, with a picture of course.
That is all I have for now, more to come once the LEDS show up.
Modified by YR240 at 12:09 PM 9/8/2009
