YR240 »
https://forums.nicoclub.com/yr240-u59227.html
Sat Feb 13, 2010 5:18 pm
After taking a "Other projects" break I have finally got a chance to get back to work on this project. Since my last post I have finished out the Lenses, they are clear and look great, and have figured out what to do for dimming the lights. My first option was a PWM to strobe the lights much faster than the human eye can process and all was well until an on vehicle test, then my 4 hours of micro soldering went up in a flame ball as the 555 timer chip shorted out. Next option was a Diode with a voltage drop to dim the lights, it worked but created a strange strobing effect. So Like the last post suggested I went the resister route-sort of and installed a Potentiometer on the running light side. It worked. Now if I can just figure out how to use my expensive new camera and get a decent night shot of these lights. here is a side by side comparison.
The light by itself
Drivers Side Break Running Light Combo plate - 35 LEDs
Doing my best to keep everything together.
Note that the light is just dangling from my trunk and it is upside down it will look better once it is in the case.
