colies97~240sx wrote:I had the same issue several years ago. There is a sensor that looks like a credit card (can not think of the technical name.) It is located under the passinger side dash. It fails then you are left with a fan that only works on 4.
You just need to order the new part from Nissan and replace it. It takes maybe 5 min. or less to do. I will check my manual when I get home to see if I can find a part number/name.
Yes and no.
The unit you speak of is the blower motor resistor, not a sensor. When it fails you are left with either full speed or no speed at all.
If you go looking for a sensor you will be hard pressed to find it, just call your local parts store and ask for the blower motor resistor, they should be able to get you one, or get you a part #, it may be a dealer only part.
