S14 Differential's
Mazza
Hey, Just a quick question for everybody!
I know there's the common diff swaps listed all over, however In my case I want to know if there are any other possibilities because I have to replace the drive shaft (It decided to become one with the diff). Perhaps needing to go with a custom shaft will allow me to get a unique diff setup? I dont have ABS either.
Thanks!
James
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
S15 Diff in HLSD case, J30 or 180sx VLSDdiff, R32-33-34 VLSD's S14 or S13 welded diff, or aftermarket clutch diffs or the mini spool. You can also use a Z32 NA VLSD with a combination of one Q45 and one Z32 axles which requires drilling the input pinion flange to match the DS pattern.
I dunno what your going for, but it's not necessary.
the-ultimate-final-drive-gear-ratio-thread-t228683.html
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
i have the s15 hlsd and love it
so are you asking for recomendations?? or just what the options are?? ^^^ pretty much covered everything
every different combination has been done, just use google to find out anything you want to know, its all there
kouki munster
Car: 97 base 240
OutToWinPAHC wrote: You can also use a Z32 NA VLSD with a combination of one Q45 and one Z32 axles which requires drilling the input pinion flange to match the DS pattern.
The na z32 is a direct bolt-in aside from swapping the rear cover(iirc just for the s13) and getting your hands on some 5 bolt axles. However, the 90-96 q45 diff requires all that you posted above to work, plus swapping to the z32 tt or 90-96 q45 rear hubs(and I think the spindles as well) since the q and the tt z use thicker axles.
Harman850T5
Car: 2003 350z
How close are you to Gettysburg? You can have a free s13 diff, it has a j30 cover bolted onto it right now. Just needs the cover taken off and sealed and a fluid change.
Mazza
I was just wondering if there were any other possibilities because I have to replace the driveshaft with a custom one. Aside from the normal hub and axle swaps.
Thanks for the offer but Im from MI thanks though!!
yvang07
Car: 240sx Zenki
OP with replacing the driveshaft you could upgrade to one of these :)
http://www.z1motorsports.com/240sx/prod ... ts_id=3877
and just throw in a 95+ J30diff and go!
