S14 Clutch pedal question
dan222000
Car: 1996 Nissan 240SX w/SR20DET
I have a 96 S14 that was automatic and I did a manaul conversion to. My clutch pedal makes a clicking noise when I press it down. Does anyone know how many bolts hold the clutch pedal assembly? I know that there are two bolts that also hold the clutch master cylinder but I can't tell if there is another bolt on top. I know that I only have two bolts holding the clutch pedal assembly againt the firewall but that's it. Maybe I need to dirll a hole for another bolt and that's why it's making this clicking noise. Has anyone else done a manual swap?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
the spring that helps push the pedal back out on my S14 used to make tons of racket, clicking and squeeking, I hosed it with lithium grease and it hasnt done it since, you can also check the fsm to see how many bolts hold the pedal assembly in.
