So the cross slotted rotors are better than cross drilled slotted rotors right?FlatBlackIan wrote:
Yes, they will crack sooner or later.
When you make multiple stops from the triple digits, say 120 to 0 and your brakes start to fade at like 30mph and there's a red light in front of you...you tend to become unsatisfied with your z32 brakes...not that I would know anything about that.flying_monkeee wrote:You'll never be unsatisfied w/ Z32 brakes...
very nice thank you...so all i need is a 5spd swap and z32 front brake....jr_ss wrote:If your car was an automatic at one period in it's life, it has or rather should have the auto brake booster. The automatic trans cars had a larger brake booster to accomodate the increase in weight (auto trans is heavier than the man trans).
Thats not the brakes. A fade of that sort would lead me to believe you are either using a cheap inferior pad compound, or your brake fluid is beginning to degrade, greatly decreasing its boiling point.Clawhammer wrote:
It all comes down to tuning ability. With the exception of Hawk pads, and DOT 5.1 fluid, my brakes are factory. I even have the stock calipers at 200,000 miles. I can easily slow my car from 100 miles an hour. With stock pads and old fluid, I could induce fade after only 2 stops, with good pads and fluid, it can withstand 5 or 6 stops before I get the same effect. As I said before though, my second set of Hawk pads are about 90% worn, and my new, bigger stickier tires can handle much higher specific brake torque. Its time for Q45s.Clawhammer wrote:I hate how many bone stock cars I see rolling around with engine swaps. /sigh
I am currently running Q45 front brakes. Ive had them on for 2 days, and my initial impressions are exceptionally good. There is a little to much front bias by just doing the fronts, but Ive found that by using good pads in the rear it tends to offset the difference a little.IHeartRPS13 wrote:Ian are you doing both front and rear or just front? I was thinking on doing just the front but i don't know how that would affect the bias. Supposedly its 78% front somewhere in that area. Is that too much?
hahahahaIHeartRPS13 wrote:HPS or HP Plus?
You are right on pretty much everything, I just have one addition.MAXIMUS Nismo wrote:Larger front rotors, wehter blank. slotted, drilled or a combination do more than provide more surface area for the pads to grip. The pads surface area doesn't change.
It's like putting your hand on a small desk or a large desk. Your hand will only touch the part of the desk it is in contact with no matter the size of the desk itself.
From what I understand, the main goal of larger rotors, better fluid, and multi piston calipers is heat dissipation.
All that energy you have with your forward momentum has to go somewhere when you stop. The whole braking unit help to dissipate the heat generated.
Calipers and Pads press against the rotors generating heat. The heat then goes into the rotors which get rid of it in various ways. Slots on the face of the rotor, the "vanes" in the middle of the rotor's edge, and the diameter of the unit itself comes into play.
The larger the diameter, the more heat it can hold and dissipate before it gets overloaded and warp.
The heat also go into the calipers which transfer it to the brake fluid.The bad part is when there is too much heat and your fluid starts to get so hot that it boil.
Then you have NO stopping power.
The braking system is a complex unit from your foot to the contact patch on your tires.
This si all I can remember for now based on what I've read in the past.
