Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Mon Dec 12, 2005 11:40 am
have you tried using the links in you know, the FAQ? Just keep the offset less than "8mm closer to the strut" and you'll clear, but beware of the suspension geometry issues you're bringing o...
wider isn't always better. And FYI:
And If I feel so inclined, I may lock this one too, since offset v. width has been discussed so much it makes my head hurt in these forums (esspecially pertaining to the S-chassis). Everything from a 7.5" top a 12" wheel width has been discussed, and anything in between (like half sizes) that haven't been, could easily be extrapolated using the resources that abound around you (IE, the FAQ's)
Christ.
"Teach a man to fish..." and all that. Try the linsk first, do some leg work and think ti through..there's LOTS of info on this....
-Chet
