BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Mon Jul 19, 2004 4:31 pm
greg,
rolling fenders is different from pulling fenders. i have pulled fenders, it's when you need to fit ungodly sized wheels on.
if you put your hand under the fender, it's like this... like an L: |_ when you roll the fender, you push the bottom part up, like this: |l all it does is give you a few more mm to play with as far as tire size. YOU CANNOT TELL A FENDER IS ROLLED FROM LOOKING AT IT. you have to put your hand under to tell.
rolling fenders is nothing, everyone should do it that has aftermarket suspension or wheel/tire combo. but if you're not going to lower it enough that the tire never gets above the bottom of the fender lip (through the full stroke range), then it doens't make any difference.
spacers.. sandwich spacers suck, but a good set of high quality spacers (H&R or wheelspacer.com style) will be just fine. just be sure to avoid poo sized wheels, even if they have crap offsets and get spacers and you're ok.
edit; i forgot, you're 4 lug... spacers for you! good 4 lug wheels are rare right now, but in about 6 months, should have a better choice.
