Can you explain to me what "such a black" means?White Comet wrote:my fc was more enjoyable to drive then my s13. price on parts isnt bad, its labor that gets you so i do it myself. my fc was na and faster then an s13, better looking, etc. its just an all around better car and its such a black to drive a rotary powered car
fixed. i wouldn't say the fb/sa is classy, if you want class and elegance, series 7 spirit R silver with red leatherhbpignosePA wrote:lulz
idk id rather have the first gen than an FC
its more classic
im in conway arkansas, anything you need at all, i can help u with. i love 240's also as ive had three now, but my friend had an fc3s with a motor that had 17,000 miles on it and that car sounded awesome, burned a small amount of oil, and was an all around blast. i agree that people give them more of a bad rap than they deserve. the cars weight dist is spot on. i say between those two, id consider seriously the rx7. with that amount of mileage tho, just keep a keen eye open for anything and see if they have good documentation that they kept the car in good shape. im no car god, im just adding my $.02 because i have a decent amount of knowledge workin on both. parts for an fc are almost as expensive as and s14 lol. i say just jump on it.zeause wrote:it wont be my main transportation but i will be driving it a lot. Heres the craigslist adds for them. The problem with finding something better is im unemployed and only have bout 2500 to spend.
http://dallas.craigslist.org/d....html
http://littlerock.craigslist.o....html
Hey man i appreciate it. From what i understand theyre like 2 strokes and are designed to burn oil. I think they even have oil droppers inside the combustion chamber or something like that. But I want something i can afford to beat on and just jumping into the rx7 and doing that sounds expensive. But you ever been to branson z fest? You should check it out, we went this year and were guna go back next year.darkvillin wrote:
good luck and hit me back if u need/want any help at all.
sounds good to me brother. this kid beat the snot out of his rotory because "someone told him they dont like to be babied" and i dont even think it burned a qt. again, im no car god, but to me id rather it burn some oil than have the apex seals go bad and not have any more compression.White Comet wrote:i have a theory on the "burnt oil". rotaries use oil as per factory design. they have an oil metering pump and injector a small amount of oil into the engine to lubricate the apex seals. normal consumption is 1 qt every 1-3 months depending on how you drive it. the smell is most likely just the fact that fc's run pig rich from the factory
