s13 sr20det rebuild costs
MrSoutherland
Car: S13 - Sr20
Did they assemble it for you as well with that price?
Sil80315
Car: 1991 Nissan 240sx
God I hope so since he paid the price for 2 Sr20 motors.
My cost for a motor rebuild is around $600 + parts for your basic rebuild, HG,Rings,Studs. I send the block to the machine shop which only costs me around 80 bucks to have them hone and clean the block.
zach-Ka
Car: 1990 240sx (SR)
MrSoutherland wrote:Did they assemble it for you as well with that price?
They should have.
Justin35ll
Car: s13 coupe sr20det
So far I'm at 898$ for the cp pistons and eagle rods shipped to my house.
Will be dropping the block off at the shop this week hopefully.
Does anyone have info on the ARP main stud issue? Mine are hitting the upper oil pan
MrSoutherland
Car: S13 - Sr20
You need to shave down 2 of them. There should be only 2 that hit from what I've read.
I sent ARP an email asking if they have addressed the situation yet. 2 months and no answer...
Justin35ll
Yeah I'm not sure which ones were hitting, but do people shave the studs or the oil pan down?
MrSoutherland
Car: S13 - Sr20
JRex
Car: 93 s13 Hatch
Machine shop told me $140 to polish the crank, acid dip the block, and hone. Sounds like a good deal to me.
MrSoutherland
Car: S13 - Sr20
Anyone have there's assembled? What did you pay?
Integra GS
Mine cost 3400 out the door..
-New Cosworth Headgasket-OEM Valve Cover Gasket-New Spark Plugs-OEM Valve Stem Seals-OEM Connecting Rod Bearings-OEM Main Crank Bearings-OEM Thrust Bearings-ARP Main Studs-ARP Connecting Rod Bolts-ARP head studs-Piston/Rings-Machine Crank, Head, Block-Hot tanked.
Might be a bit much.. but worth it since I never worked on a SR before
They removed the engine, did the tear down, the machining, and the re-installation.. along with all the fluids. They also did a few other things too that i didnt list..
MrSoutherland
Car: S13 - Sr20
I guess that's not bad since they did everything.
Justin35ll
I just dropped off all my stuff at the machine shop and I'm already looking at 750$
Bore and honeDeckAlign Hone mainsHot tank/ prep workPolish crank
If I have him put the bottom end together I'm lookin at 1100$ out the door.
A little more then I was expecting.. but I wasn't planning on align hone and thats almost 250$ alone
Asia989
Car: 90 s13.4
MrSoutherland wrote:Anyone have there's assembled? What did you pay?
250
MrSoutherland
Car: S13 - Sr20
That's a damn good price IMO as long as it was done by someone who knows what there doing.
Asia989
Car: 90 s13.4
MrSoutherland wrote:That's a damn good price IMO as long as it was done by someone who knows what there doing.
the man has built more than 80 sr including 2.2's, and is z fevers tuner
MrSoutherland
Car: S13 - Sr20
Hell yeah then!
