supreamS14 wrote: Do you have a S14 sr20det and want to swap in the s13 sr?
Nope , I have an S13 SR20DET and want to swap it into an s14 chassis
FlatBlackIan wrote:I have a redtop SR in my S14.
Yes the wiring is different.
All the mounting is the same.
You will need to reuse the S14 speed sensor, and some of the parts for the power steering.
As far as I can remember those are the only differences between swapping the two. I would do a little research if I were you, there is tons of info regarding this.
Welcome to Nico.
Thanks for the info , I did search but to no luck . I did find some S13 SR's in S14's but it did not specify WHAT was different about swapping them in ..
