I'm going to look at a 1992 SR with a blown turbo... want to make sure it's really an SRSpeedRacer1 wrote:
What do you need this info for?
it's not a Lie, the S15 6 speed is weaker than the SR 5 speed. Ive had friends in japan that broke the 6 speed and switch to the older 5 speeds.JustinStrife wrote:It's a lie about the S15 transmission being weak. It isn't. A rumor spread by superstreet or one of those magazines.
red top < maroon topSpeedRacer1 wrote:
Its odd, Some times the redtop valve cover will show up as a flat red, and other times it will look like a very rich red and some very dark red.own3d wrote:red top < maroon top
No and no. I have seen plenty of redtops with heatsink fins that were very stock and were definately in 1993-1994 180SX's.ETTInnov04 wrote:Just go with me here for a sec. Is there any chance those of you with the fin cast heads may really have a blacktop head on your redtop or a blacktop with the redtop valve cover? This was the first I'd heard of red tops with the fins cast on the front. I mean im sure in japan they warp heads or go to the junkyard to find another head to have work done to so they dont have to put their car down. Just a thought.
Also I thought there was a difference in the head design of the red and blacktops. Not between the S13/S14/S15, I know those are different but between the S13's alone?
there are differences in our driveshafts...even the CA and SR driveshafts are different i believe...but the 89-90 driveshaft is slightly short than the 91-93 driveshafts...it also is designed differently where it inserts into the transmission...the head on it is shapped differently...i havent had a CA and SR driveshaft side by side...but the CA looks WAY different than the Zenki 89-90 USDM driveshafts do (my best friend just did a CA swap)Silvia13BT wrote:Hi I have a s13 blacktop and how can I know what year it is? Because the 89 driveshaft doesn't fit with the bt transmission. I think is because the bt have a s14 transmission...maybe it's a 97-98 bt?Also, is the s14 driveshaft will fit on the 240sx 89, if I change the lsd of an s14?Thanks for all the response.
Pistons = There are different pistons on the S13 SR's but its not a redtop/blacktop difference. It is a difference between the 1991-July 1993 S13 SR's, and the August 1993-Dec 1998 S13 SR's. Blacktop S13 SR's came out in Jan 1994. The pistons aren't better, just different.ShadowArtsS13 wrote:I also fund out the S13 Blacktop pistons,water pump and oil pickup is better than the S13 redtop.
