For my KA-T, I want to remove the PCV valve and connect an adapter to the air box and run a hose to a catch can. Basically, I want to vent the engine blowby to a catch can and atmosphere.D-UNIT wrote:what are u trying to do? A brand new pcv valve is only like 11 bucks from the parts store.
Your idea is awful. But you have read enough to know that. I'm saying it's a bad idea so that others don't think it's going to work...cause it won't.supra33202 wrote:http://www.honda-tech.com/showthread.php?t=697498
After reading ton of PCV system threads from Nissan, Honda, etc., the only ways to create vacuum are to connect PCV valve to exhaust or install electric pumps.
Connect the PCV valve to intake is not a good idea, because having unmetered air entering intake will create idle/tuning issue, and the PCV valve will shut under WOT/boost.
Venting PCV and valve cover breather to atmosphere is not the best way, but it works fine for many people. I saw many professional race car/drift car also use this setup.
I think I will connect the PCV valve opening and valve cover opening to a oil catch can with a breather. So the crankcase pressure will be vent to atmosphere freely (no PCV valve).
http://cgi.ebay.com/ebaymotors....m245
I've been looking for a correct way to setup can catch & pcv system too. It seems like there are many different ideas out there.95ka24de_zenki wrote: What is the right way to set up a catch can. I've been searching but haven't been able to find out exactly how.
Actually believe it or not the ecu does account for pcv air ie it is metered. My car idles funny when I take that hose off. Well this not the best way but this is how I did it. PCV -> catchcan -> inlet of turbo after the MAF. At idle the turbo is sucking in a fair amount or air , but when you are boosting more than enough air is rushing though that pipe to suck out crankcase gases. And it is still a closed system so no weird idling or ecu issues.supra33202 wrote:http://www.honda-tech.com/showthread.php?t=697498
This method is the most common, but is operating at about 25% compared to the stock system by itself. So you're actually losing 75% of the suction by doing this. So common doesn't make it right.D-UNIT wrote:
Cool. Looking forward to see your FAQ.WDRacing wrote:I'm going make a new thread today that outlines the various ways to properly evacuate the crankcase along with the ones that don't work to well.
Then I'll add it to the FAQ.
WD
WD
Ever watch "Beerfest"? Thats how my last 2 days were spent...lol. I'll get that write-up knocked out today. Sorry guys...life kidnapped me and beat my @$$.supra33202 wrote:
Thanks!
I celebrated my B.D. last weekend and things got a little crazy Didn't feel too good the next day thoughWDRacing wrote:
WD, thanks for the guide!
