AZhitman wrote:DOH - Never mind...
Can't use S-Techs on a 'vert... Gotta go with coilovers.
$750 for TEIN Basics? Crap...
since when? that's what i'm running. the ultimal rate is much stiffer than what the stock springs run.
S-Tech = ~3.7 kg/mmStock = 2.2 kg/mm
while the vert ways more, it's evenly distributed, and the ultimal rate of of the springs is well over an extra 1 kg/mm over the stock spring rate.
EDIT: Sorry for the lateness in reply. I've been on vacation all week, and I was able to hijack a computer at my relatives for a little while.
EDIT EDIT: I forgot to mention that all verts run the "sports" package that came on some of the S13s. They get the slightly stiffer springs and the rear anti-roll bar is slightly larger (same as any S13 with the sports package). Also, all S13s came with the slightly larger rotor and caliper from the ABS equipped S13s without having to have ABS.
