PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Wed Sep 09, 2015 4:58 pm
I believe the lower harness IS specific to the trans, as it has reverse/neutral sensors, etc. For all I know, the auto sensors could be the same though. Nothing should be different on the front (alternator/starter, etc).
Driveshaft length will also depend on if one of the cars was ABS, or you are switching auto to manual. You might want to just measure to see what length of shaft you need.
