s13 ka-de not firing!
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
This is FSM material CR.... But like Steve says, you need to understand it, and you need the tools to test it.
costa_rican13
Car: 1993 s13 coupe
what should i do if my obd1 scanner doesnt connect/read my ecu?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Check the ignition power, battery power and ground to the ECU
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Well now you are onto something.
That might explain why you have no spark...if your computer has no power.
You should be able to use a test light for this test.
Check the small red arrows first.
costa_rican13
Car: 1993 s13 coupe
with the key in the in on position correct?
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
one should have power all the time and one should come on with the key
costa_rican13
Car: 1993 s13 coupe
car runs guys!! finally!! it was the ignition control module ground was bad, which then fried the module. so fixed both and fired right up! thanks steve and kevin!
