2nd. I am on my second cluster and dont dare touch it anymore. lol94_240sx wrote:You were lucky. People, don't do this. If you pull the needle a little too hard, your speedo or tachometer won't work anymore. It's not worth taking a risk IMO. OP that's good job you did without damaging them. Red should be darker like 180sx kouki needles. Too bright for me.
please, do elaborate!NISSAN240SX12 wrote:the trick is not to pull the needle out. the needle has to be twisted out.
DriftBoy07 wrote:I did the same thing You dont have to pull the needle off, just do the top w/ a sharpie lol
lolzAZ89two4Tsx wrote:Ummmmmm.....why didn't you just color the needle with some paint or something? Even a sharpie would probably work.
pix plz when u do thisScuffed_ChukiCoupe wrote:cool, im gonna sharpie mine purple!
i spy a mk3 supraNISSAN240SX12 wrote:well since i have no job right now im just trying to keep busy. i went to the junk yard and picked up red and orange gauge needles off a 01 Sentra. i decided to go with the red here. the two bigger needles are plug and play. the other two needed a little bit of modification but it all worked out pretty d@mn good i have to say. I'll shoot a pic of it lit up tonight.
Modified by NISSAN240SX12 at 6:40 PM 9/14/2009
Rice.Scuffed_ChukiCoupe wrote:lol wait how do i even get to the needles? My sparco's r purple accented, my glove box is covered puple so hey purple needles! But yea how do i get to it? i have to push off the clear face?
On a s13You have to drop the steering column there are 4 12mill bolts keeping the steering column up. Two are just nuts on a i think a bracket that should be w/e color ur car is near the pedals, and 2 more bolts closer to the wheel they're kinda hidden. After the columns down remove the 2 panels behind the steering wheel that wrap around your ignition. Thats 6 screws then remove the panels and the plastic shroud around your cluster i think has two screws on the bottom with two clips and 2 screws on the top of it. Remove that and your cluster should come off after that they're might be a few more screws. The clear plastic is clipped on its an easy removal. The whole process should only take 10 minutes.Scuffed_ChukiCoupe wrote:lol wait how do i even get to the needles? My sparco's r purple accented, my glove box is covered puple so hey purple needles! But yea how do i get to it? i have to push off the clear face?
