jdm_master_X wrote:you cannot mix R-134a and their components that ran R-12 previously. reason is because the oils that are carried within the refrigerants are not compatible with each other, and can gunk up and clog the lines. so when doing the conversion, you must get the entire car retrofit for R-134a (nissan sells the kit).
R-134a operates at slightly higher pressures than R-12, and boils at a higher temperature than R-12, but is just as efficient.
you can go ahead and keep R-12 if you can keep on affording to buy it. It's getting expensive.
the lines for R134a have different flanges and connections, so quite possibly the connections to the compressor might be slightly different.
you'll be in for a treat if you mix the systems....but if you do retrofit, make sure to get ester oil, at least thats compatible for both systems during the retrofit process.
I don't mean any offense, but none of that is true except the part about ester oil.
R-12 is a CFC and thus contains chlorine. Chlorine is not compatible with PAG oil which is what is standard for R-134a systems. Even after removing the R-12 there will still be remnants of chlorine which is why you have to use POE (ester) oil when converting to R-134a. The chlorine will break down PAG oil, thus eventually destroying the compressor due to lack of lubricant. Just use POE oil and this is not a problem.
Desiccants are the other incompatability. XH-5, which is used in R-12 systems, is not compatable with R-134a. This is another mute point as you should replace the drier as a mantainence item anyway. Any new drier will use an XH-7 or XH-9 desiccant. Again - no problem.
The hoses were expected to be incompatible with R-134a's smaller mollecule size, but it has been observed that most hoses were sufficiently sealed up during their operation with R-12 so this is frequently not a problem.
R-134a is less efficient than R-12 hands down. R-134a systems use larger condensors, larger evaporators, and/or other changes to make up for the decrease in efficiency.
The seals in some compressors have been shown to fail with the use of R-134a. Some do; some don't. It's about as simple as that.
The EPA requires different connectors on the service ports for each different refrigerant type. Nothing else is guaranteed to be different/alike.
And specifically regarding 240s, it has been my experience that they perform well with R-134a with nothing more than a drier change.
