RX7 460cc Injectors - Modify to fit or not?
sicj
Car: 1987 Nissan 200sx hatch, 1992 240sx coupe
So I came upon 5 FC injectors at the yard. They are the orange top 460cc injectors.
Now we know that stock are 370's and to buy the R33 444cc injectors costs around ~$200 so falling upon these seems like a great deal. Only one problem...they don't fit the rail OR the secondaries.
The top of the injector is marginally bigger than the stock CA's (@ the rail) the bottom of the injector and it's sealing ring are about 1/16" too big for the secondaries
I was thinnking of boring out the rail and secondaries to accomodate the larger FC injectors. Other than the top/bottoms of the injectors everything else is identical between the two injectors.
So is this a good idea to modify the rail/secondaries to make them work? The engine is going through a rebuild right now so taking things apart has already been done
Thanks.
bias
Car: 89 240sx hatch 93 240sx coupe
I didn't. Just went with 450cc from eclipse(what if you want to upgrade one day ).
My car didn't have any lean issues when I first put them in.
Whatever injectors you use make sure they are in great condition. It's a lot of trouble pulling apart the manifold to test things out.
sicj
no other input?
thanks.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
SEARCH. there have been serveral threads on this topic
sicj
RX7 InjectorRX-7 Injector460cc injectormazda injector
all resulted in nothing...
ca18detgabby
03 Infiniti G35
sicj
Thank you!
Just need to get the CA injector seals/o-rings and I'm set.
ca18detgabby
03 Infiniti G35
if you flip the search over to archive there are a bunch of threads about it
np
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
ill sell you a set of DIRECT DROP IN 450cc DSM injectors right now for $75 shipped...
[email protected] is my email. no modifiying needed
sicj
thanks but all I need to get the the stock CA seals and install them on the RX7's and they'll work. Plus I could use that $75+ to get them flow tested.
thanks again.
