SHIFT_240sx »
https://forums.nicoclub.com/shift-240sx-u11151.html
Wed May 14, 2008 11:35 am
so yeah i noticed today my car was boggng pretty bad so i brought it home and checked my plugs, black as night, so i changed my plugs and went for a test drive, same problem.
i noticed that black puffs of smoke were coming out of the tailpipe, but i remember this happening when i tried to plug one of the vac lines coming from the throttle body to the carbon canister, it had the same exact symptoms until i reattached the vac line and everything went back to normal, then one time i gapped my plugs wrong and the same symptoms showed up again.
recently, i had run the car for about a day or two with my air hose that goes from the TB to the cold pipe half off the TB and i wasnt boosting properly until i figured out the problem and put the hose back on properly. After this the bogging problem is back, my air hose has some cuts at the bottom so maybe its a vac leak again but i dont know.
im thinking about changing the fuel filter and seeing what that does, anyone have any suggestions?
