Yep check your fuel pressure, also, pull your spark plugs out and check the condition of them.bonestocksr20 wrote:i was leaning toward fuel pressure regulator but i will check the timing and let you know
You will need a fuel pressure gauge. I would suggest pulling the plugs out again, if one of your injectors is stuck open that plug will be blackas night.bonestocksr20 wrote:spark plugs are less than two weeks old and i checked the timing and it was spot on,this may sound stupid but how exactly would i check my fpr???
