Ca_Silvia »
https://forums.nicoclub.com/ca-silvia-u34581.html
Tue Jul 08, 2008 7:24 pm
Ok man, out of everything new you installed 2 of them effect the air flow/pressure.
Z32 MAF, is it sealing properly? lose connections between air filter and MAF or MAF and turbo intake.
Throttle Body, again is it sealed properly. My throttle body shaft seal was leaking on mine. But a boost leak test made that clear to me. Double check that stuff, good luck man.
Oh ya i re-read your thread. FYI after months of boost leak testing i can only get 16 psi on vacuum on idle. I hope thats reassuring
