MandTPhotography wrote:I imagine in limp mode it's REALLY slow...it's not like that.
I couldn't tell you if I was throwing codes...I'm not sure, myself.
Actually limp mode isnt as bad as you might think. The ECU locks the timing to stop detonation, and it adds slightly more fuel. Some people would not even notice it, except for a decrease in gas mileage. The car will feel like it comes onto boost late, lacking power in the mid range, but feeling fine near redline.
I would strongly suggest checking for ECU codes, because most swapped cars will not trigger the check engine light.
MandTPhotography wrote:I honestly think the problem is my AFC is a POS.
If it my alternator is putting out 14.0 volts and my Battery is putting out 12.7, then there isn't a problem....right?
Well, its hard to say, it could be a problem that only occurs at high RPM. A full load test is the only way to really test it.
