I tried heating it up for 2 mins then spraying it with water to make it cool down really fast. Supposedly its the fast change in temperature that breaks it loose. However, I read that doing this weakens the bolts....right now Im scared as f*** of snapping one of those bastards or rounding them off because then I will trully be fubared. I will try your method though...gonna pick up a longer breaker bar in a few.j-z wrote:when you heat it up, dont wait for it to cool down. that defeats the purpose. heat=expansion.
Yes Ive already adjusted the regulator on the gun itself. I saw on some fiat forums those tools to lock onto the teeth and was thinking of getting them. Im going to harbor freight today and if I see them I'll pick them up...dont want to have to buy them online and wait even more to get this done with.CSUPUEBLOTIM wrote:Make sure you have the air regulator on the gun turned up as well. If the flywheel its self is still spinning they make a special tool that locks itself to the teeth so that you can hold it from spinning without loosing a hand.
thanks for the advice will give that a shot as well....only problem is that Im doing this by myself and the only help I have is the fsm and online forumsaceofspds wrote:If that wont do it for you get someone to put a breakerbar on the crank and go up under the car and use the biggest cheater bar u can.
yes IR does make good tools. They make most of matco, and mac i know for sure.You can get a IR for around $125 that will do the job.Remember to oil it and it will last a long time.Also fyi turning up you regulator doesn't do much good.For many years air tools are meant to be ran at 90psi for optimum performance.Ian i assume you have the newer snap on 1/2" that hits over 1000 ftlbs reverse.Wc240 wrote:igersol rand (IR) makes some of the best guns. try them
Everybody has been there, tools are expensive, really expensive. I honestly have more money into my toolbox at work than I do into my car.tmwnn wrote:Thanks for your replies and I agree with you. Believe me ever since I started working on cars and learning everything by myself, one of the greatest lessons I've learned is the importance of having good quality tools and using the right tool for the right job. I would love to have a sick set of snap on tools and air guns but if I don't buy them its because I can't afford them. Right now Im in college, unemployed, and the reason I got into cars is not because I wanted to be a tuner but simply because I have 4 siblings and I wanted to save my mother money when it came to auto repairs. Hell, I even had to lower the transmission using a 2 ton trolley jack because I didn't have a 3 ton one.
I was considering renting a heavy duty impact gun, but the smallest one they had consumed 24cfm and there's no way I could run that...
With that said, Im gonna test the HF impact gun and see what it does...I want to get my hatch back on the road already. Wish me luck
WD-40 does not work as a penetrating oil, hell, it doesn't even do a very good job of lubricating.DRIFTKNIGHT_240 wrote:did you try WD-40?
nonsense, all my tools are from walmart and advanced auto, i dont make enough to buy "quality" tools..but then again ive NEVER busted any of my tools yet and i put my s*** through hell...as stated above with the bfg, on a walmart ratchet..still using it too, have been going on 3 years. right tools for the right job...eh most jobs on these cars require some sort of rediculous compromise and creativity lol.tmwnn wrote: one of the greatest lessons I've learned is the importance of having good quality tools and using the right tool for the right job.
Definitely agree, but with my current situation I cannot justify spending $200 on a tool. Ingersoll is nice as hell though so in the future I will upgrade when I have the chance.FlatBlackIan wrote:That being said, there are certain places where spending money is important.
Yes I tried going Thor on the bastards but didn't really work and I didn't even want to risk messing up the head so I stopped.24j0hn wrote:did you get it off yet?... im gunna be doing my clutch tomorrow and friday at school... have you tried w/ a hammer? also try to hit the bolts themselves with a hammer to loosen all that grime on the threads...
Sweet idea, Im sure that would allow a big breaker bar to be used.hbpignosePA wrote:buddy of mine had a good idea for this.... put a chain around the motor.
