jcquick »
https://forums.nicoclub.com/jcquick-u25031.html
Sun May 18, 2008 9:50 am
I have a S13 Blacktop in a 96 S14 with a bunch of mods, Engine related such as: Apexi intake w/ Ejuku Racing Intake Pipe, Greddy Intercooler, Recirc. BOV, Profec B Spec II Boost Controller, Turbo Elbow and Downpipe with a 3" Exhaust, Megan Exhaust Manifold, Walbro Fuel Pump, Nismo Adjustable FPR w/ gauge, custom oil cooler w/ remote filter.
This is my first turbocharged vehicle, I've never dealt with this type of problem. I would like to thank all you guys for all your help, since this website is where I've learned all that I know about the SR20DET/240SX.
The problem I'm having is when I'm cruising around or during the vacuum to boost transition. When I'm going at a steady speed (i.e. 50, 70 mph) or when I slowly accelerate and begin boost with a reading of 1-2 psi, my Wideband intially reads 14.6-14.8 A/F but then it feels as if there is a loss of power and it begins to read lean 15.8-16.0 A/F. I figure this occurs at a certain position of the throttle (25-35% in reference to WOT) because when I let off just a bit the A/F goes back to normal and it feels like I regained the power. I thought the engine was starving fuel so I installed the fuel pump and Adjustable FPR with a idle of 42psi (vacuum line connected) and the problem still continues. Any suggestions??
Additional Info: I don't have any leaning out issues under hard acceleration or full boost. Also, my boost controller isn't the issue since I've been having this problem even before I installed the Profec B. Full Boost is at 11-12psi with a reading of 12.3-12.8 A/F. Also, when I change out my plugs every oil change they appear white (lean).
