I have a ka24det, and i have a tuned ecu for 370cc and stock maf. When i do a 4th gear pull on the street, all the way to 5k the car runs a good afr. From then on it jumps to about 13 afr all the way to redline. So i added +50 fuel from 5k to redline, and the afr dropped to 12.3. I dont think im maxing out the injectors on 7-8 psi on a s14 t28 bb turbo. What do you guys think it is?
1. You swapped out the MAF so lets rule that out.
2. We still don`t know what fuel pressure you are reading. All ECU`s are programmed for 34psi at idle to +1 psi per pound boost. So you will need to buy a mechanical gauge and a adapter all for around 30 bucks to make sure the fuel pressure is reading correctly. You will have to do a pull on the dyno and look at that gauge to make sure it is reading correctly.
3. If the fuel pressure is reading correctly then we have ruled out fuel pressure. Next I would give the person who tuned the ECU for the 370 injectors a call and see what he says. The other thing you can do is send the injectors to Deatschwerks and have them flow test it.
Unless you do these things it is a guessing game. When trouble shooting problems such as yours it helps to test components so that you can eliminate the components that work to narrow down what the cause could be.
I found this book to be a great help learning about EFI. It give you a basic understanding of the EFI systemhttp://
www.efi101.com/
I would love to go to those classes!
