david200095367 wrote:also i started my car on a cold start and the idle afr was at 12.3 ish so i minused 9% and it was at 14.7-15 afr at idle. so i drive it for 20 minutes and then i stop at the idle is back at 12.3ish with -9%. So i minus some more fuel and it doesnt do anything. I minus 50% and still nothing. then i add fuel and it gets richer. So at idle it wont get leaner but it will get rich when i mess with the fuel. And if i mess with the fuel before 5k rpm it works, but after 5k it will only richin up from 13ish to 12.3 ish after i add 50% (this is in full throttle). Something is wrong here and i dont know what. Anybody else have any suggestions?
Thanks to all who have contributed so far!
Not that this helps since the pronblem was solved, but you should understand that except at full throttle and shile the engine is stil in cold start mode, it uses the 02 sensor feedback to try and reach the target A/F ratio. So adjustements made in a piggyback are largely useless except at WOT. This is what many experts talk about when they describe the ECU as fighting the piggyback. This is also why a piggyback can be dangerous when running a much larger injector than the ECU is programmed for.
