running a t-25 on a ka24de, is it worth it??
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
what kind of ic piping and fmic can you use with the sr mani with ka flange?.... can you use a fmic and piping kit for an sr20 since your using the mani?
AceInhole
i'm assuming that you can use all the SR intake/ exhaust components as long as the manifold is made correctly.
The intake cold pipe must be from an S13 though, as the S14 has a different throttle body position.
MikeMurphy
Car: Guess
Ace what are you using for motor mounts? stock?
tapdeznutz
when u cut the sr flange off and put the ka flange on the turbo manifold did all the holes and stuff line up or did u have to tweak it a bit? cause it sounds like i and get the sr manifold from SScrhome and get a ka flange and it should work. well granted that there are not too much tweaks to be done
AceInhole
MikeMurphy wrote:Ace what are you using for motor mounts? stock?
hdSPL
AceInhole
tapdeznutz wrote:when u cut the sr flange off and put the ka flange on the turbo manifold did all the holes and stuff line up or did u have to tweak it a bit? cause it sounds like i and get the sr manifold from SScrhome and get a ka flange and it should work. well granted that there are not too much tweaks to be done
the port spacing is the same.
i tweaked mine by squaring the runners.
my friend did not, and he also swapped the turbine flange to use a T3.
in order to use the SR o2 housing and downpipe, you need to extend the runners slightly, or clock the manifold a bit. probably best done with the car there so you're sure nothing interferes.
hayato kazami
Car: 1997 240sx SE
does anyone know where i can get the KA Flange, i can't find it over the sites.....
Thanks!
WDRacing
http://www.jgstools.com/turbo/index2.htmlThey sell the SOHC and DOHC flanges...
Structure240sx
Ace when you said to extend the runner did u mean from the head flange or from the turbo flange and how much? how do you square the runners? It seems this will definitily be the setup of my next 240.
AceInhole
extend runners from the head flange to place the turbo further from the block (not that it'll hit the block, but the downpipe might hit the transmission). You don't need to do this if you're making your own O2 housing/ downpipe, or if you're using a T3.
Squaring the runners = making the circular shapped piping more square looking.
cyrus240sx
im new to welding...... how would you extend the runners?
Structure240sx
ok cool about how far over did u have to move it?
i know making them more square to match the ports but how did you? your friend that didnt do this, does it overlap any of the flange ports?
AceInhole
I'm guessing it overlaps the ports since he didn't do it (i never saw his mani in person, as of yet). as far as how far to move it... i'd say .75", but it'd be easier to just do it on the car so you know for sure. My measurements were already off once.... so depending on how accurately the flange is clocked it may differ slightly.
MikeMurphy
Car: Guess
AceInhole wrote:hdSPL
Could you exlaborate pls? I cant seem to find any information on this. Thanks.
AceInhole
hd = home depot. they're filled with polyurethane window glue.
s86d
Car: autocross, backroad racing, and working on 240's
hey aceinhole do you have a aim or yahoo IM name. I would really like to have your knowledge on this seeing as how its prolly my (plan of attack) now.
AceInhole
just search FA. it's got everything i know and more
WDRacing
Good god....FA is the DEVIL!!!!!!!!!!!!!!!!!!!!
AceInhole
lol. FA is where I started out. Seems like I only post there when I have something absurdly technical these days, though.
C-Kwik
FA has a lot more of the veteran 240SX mail list members. Tehre is a lot of knowledge there. Many of those guys are also the ones that discussed and tried out somewhat innovative thinks like the hacked MAF. I don't post there much, I but know many of them from the email list. Only a handful of the veterans on the email list seem to post here. Oh, how I miss the email list. Or at least all the discussions on it. We see so few messages there now. Amazingly Dave Alexander still keeps it open for us. despite the fact he doesn't even own a 240 anymore.
s86d
Thanks i just went to their site I think the server is down :(
one more reason why I like NICO
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
Hey WD. What's the status on your turbo kits? Haven't heard a peep in awhile and we're almost into March :D
hayato kazami
Car: 1997 240sx SE
AceInhole wrote:extend runners from the head flange to place the turbo further from the block (not that it'll hit the block, but the downpipe might hit the transmission). You don't need to do this if you're making your own O2 housing/ downpipe, or if you're using a T3.
What about the T28 as you may want to use later?
