that is very strange, you just replaced the MAFs correct? and youve check voltage on all the related sensors,
So, as it stands, anytime positive manifold pressure is reached, the engine goes super rich.
do you have a laptop computer? it may be time to wire up the consult port and get yourself one of these
http://www.blazt.biz/ the writeup for how to install it is here
zerothread/268436
Because you cannot pull codes from the ECU, using that program will allow you to actively monitor all of the engines sensors, that way you can get a much more accurate idea of what the engine is doing under certain situations.
Either that or you could pick up a used ECU from somwhere, because trying to troubleshoot an issue like this without being able to talk to the ECU is like trying to do a rubicks cube while wearing a blindfold, its also possible that the ECU itself is the problem.
hope this helps some.
