Ruckus-racing mounts: few questions
240z4u
Car: '95 Nissan 240SX
Neejay wrote:Did some more research. I found out that the hockey puck method is 2" (1" x2).
I then found this pick of the hockey pucks vs. Nismo mounts. According to this pic, 2.5" should be fine to fit Nismo mounts.
EDIT: And if the Nismo's are too tall, the hockey puck method is easy and cheap.
You guys are crazy, hockey pucks are for body lifts! lol
meet07
Car: 89 180sx rb25det
I was going to run by d!ck last week but never got around to it. How much will 4 pucks run??
Neejay
probably like $5 with tax. lol
meet07
So you pretty much get the radius of each puck and drill right through it huh???
I think the pucks might suit me better. Im going by d!ck today...lol
Neejay
meet07 wrote:So you pretty much get the radius of each puck and drill right through it huh???
All regulation pucks should be the same height: 1"
Neejay
Cool, that's reassuring. What isolators are you using with the kit?
Neejay
dftsilvia wrote:my stock ka one's they are still in pretty good shape so i am using them for now. of and my hood clears too. the back of my engine is literally a half inch from the firewall it sits really nice. a little tip for you if your going rb25, i had to "massage" both sides of the firewall about an inch to get the transmission to sit in there properly and not it.
Cool, cool. I'll be using my Nismo isolators. Mine should be here soon, and yeah, RB25. The guy I'm getting to install it will know what to do.
meet07
Looked up the hockey pucks on d!ck web site. The prices are great.
.99 cent up to about 3.99
http://www.d!ck....55231
Neejay
Just an update. Motor is finally in and Nismo KA mounts + ruckus-racing mounts = too tall for hood to close. They raised the rear of the hood up, like some people do for the "cooling mod". I tried some volvo mounts, but they weren't tall enough and resulted in the mount bracket to not sit evenly on the top of the mount = no no.
I'll try some e30 mounts and/or flexane 94 custom method and/or hockey puck method. It's cold now, so I can't do too much without a garage...I wish I knew for certain which would work correctly so I could do it one time only.
StricNyne
cool update pics or ban !!
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Neejay wrote:It's cold now, so I can't do too much without a garage...I wish I knew for certain which would work correctly so I could do it one time only.
Cold in Atlanta?! Are you serious? If it is above freezing, you can work on the car outside if you bundle up real well.
Neejay
lol! I live in apartments, and I don't get home until it's basically about to get dark. Lately, it's been in the mid to upper 20s - lower 30s at night.
Neejay
StricNyne wrote:cool update pics or ban !!
lol! It's not out the shop yet...still waiting on the e-fan and 1 piece of the smic piping....and payment.
nismo8117
Car: 93 SilLine
thats weird i used nismo mounts on the same kit and had no problem with the hood closing...
Neejay
lol...I'm using the stock intake manifold.
nismo8117
Car: 93 SilLine
oh....my bad...
rbs14kouki
Car: rb27det s14 / sr20det s14
i run hockey pucks (only 1 compare to the pics it's 2) and the cam cover rubs a bit) on my rb26 s14 ... mcKinney mounts .
works great and it's cheap ... i must have 100 of them here in my house ... hockey is our favorite sport up here in Canada !!! lol
meet07
ive had my swap in now for about 5 months and noticed that with the ruckus mounts, and hockey pucks the oil pan rubs the swap bar. After being tightened the pucks kinda compresses a bit. Im not happy with it so ill be ordering some solid insulators. Plus my dp is rubbing the steering shaft. Im hoping that if I get the insulators that I spoke about before that the extra.5 inches will allow the dp elbow to clear the shaft.
USMCgetsome
SHAVE THEM HOCKEY PUCKS DOWN!!!!!!!!! You can custom fit them.
dsm007
Car: 1995 nissan 240sx SE
dftsilvia wrote:well guys i got my ruckus mount kit fully installed and all my major components on her. the sway clears for days its not even close to hitting anything which is real sweet! i had to grind prolly a 1/16 of an inch off my turbo elbow to get some extra clearance, which took all of 2 minutes, and my greddy skyline downpipe that i got from a friend bolted right up to my apexi cat-back! i will get pics shortly. i will take a pic of how much i had to grind the elbow on my lunch break cuz i have to burn out a broken stud
Did it bolt right up without a test pipe?
Neejay
My hood didn't close with these. I had to raise the rear up about 1 inch.
Zerolift Autolab recently bought the rights to the ruckus-racing mount kit, and modded the original ruckus-racing mounts (regular KA mounts) + modded for Nismo KA mounts (wasn't taken into account for the original ones). He sent me the Nismo customized motor brackets and everything fit (no sway bar spacers needed, hood closed). I'm not sure if they will just sell the motor brackets seperately, since I was basically the 2nd test mule besides the car used for fabbing them.
meet07
why shave??? I need more height.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Hmmm, a semi retired thread... I'll post my review up though.Ruckus racing mounts are OK, but i think its worth the money for the name brand. I ran into the issue of the hood not closing when used the KA mounts so I made some custom solid steel ones. After I installed the RB i notice that when i let off the throttle the plates BEND like a piece of spaghetti. So i had to weld away at them in order to make the sturdy. The flat plate that comes out for the mount is way too weak. I also have a silvia front conversion.This is fine until I upgrade the turbo and manifold.All I have done to the motor is a rebuild, CP forged pistons, new intake, .60 AR turbo W/ top mount manifold, MLS head gasket, N1 oil pump, FMIC (2.75 piping), head port & polished, greddy timing belt, along with the small things.
