Rkitkt wrote:I have noticed that my 3.5 will idle rough at times. Is there anyone else out there that has noticed this. Do you guys think that there is anything that the dealer will do to help with this problem, and if so do you think that I should put my stock air box back in before going to the dealer?
Don't know about the airbox, but even though I'm usually all for home repairs you should take it in. There's a recall on 2.5's for a rattling heatshield and it causes the rough idle, mine got fixed and its a huge difference. I know you drive a 3.5 but something like that is almost always covered by the warranty, and it could be something simple or you could even need new motor mounts.
Try this test, have a buddy stand in front of your car withthe hood up. With you in the car, shift from park to reverse, reverse to drive, and then back again. Ask your buddy to watch the engine itself, and If the engine moves or turns at all when you shift, you have engine knock, which is usually present when theres a rough idle. just remember to never ever take your foot off the brake, or youll lose a pretty good friend.
What does the rpm gauge read when its rough?
