S13FASTBACKSR wrote:you swapped your coilpacks around to different cylinders already though and the same thing happend...
I meant I took the coil pack off the plug for the #2 cylinder and hooked it to the plug on the #1 cylinder and it still didn't fire.
I think the problem could be my ECU, When I got my clip it had a remanufactured ecu with a sticker on it that says KS ROM. ( there are pics in this thread
zerothread?id=128032 ) It doesn't have a code light on it.
Also I checked continuity on all the wires and it was good.
streetspirit7 wrote: I also checked The ground wire that goes to the engine block off the back of the coil pack harness(it goes to the E on the coil pack), on cyl #2,3,4 it shows around .024-.072 mV and on cylinder #1 it reads from .024 and quickly raises to .271 mV then resets to zero and does it over.
Does that sound odd that my ground wire would be reading a voltage like that though?
