9 views and no replies? Tsk Tsk guys.oovmiester25 wrote:I have a 1990 Q45. About two weeks ago, I got in my car to drive and I noticed that it was idling rough and at only about 500rpms. After about an hour it just smoothed out all by itself. I never gave it a second thought. Now this morning I let the gas run down right to the empty line, but not below. It started running rough so I pulled into a gas station imediately and put gas in. The car has been running rough all day now and it doesnt seem to be smoothing any at all. I am concerned that the ignition system might be detonating to the block or head and since they are both made of aluminum I know that driving it like that could make the metal look like lava rock. If anybody that knows what they are talking about has a little insight or whatever please. Thank you!
Ah. I'd forgotten to ask about those issues.maxnix wrote:Since you preovide no maintenance history, your most immediate problem could be your timing chain guides. Read the Article that pertains to this before you ever start your car.
Now tell us in particular about intake path and fuel system maintenance. ISO-heet? BG44K? Fuel fiter? Fuel pressure? Power balance test?
Excellent post Reji. The links pretty much sum up the free and easy stuff (except for $15 worth of gaskets and some brake parts cleaner) and give the owner a good start towards troubleshooting the basic problems. Add a link to pulling ECU codes and it's all there.Haitian_King wrote:Here are some tips to help those issues and at least be able to rule them out if the problem isn't resolved.
MAF:http://www.q45.org/maf.html
Fuel Injectors:http://www.q45.org/ohminjectors.html
IAC Cleaning:zerothread?id=33796
Throttle Body:http://www.q45.org/tbclean.html
Those are some of the best fixes for rough idles. Go through them, and see what works. Come back when you're done and if it's not sorted out, I'll be here to help along with the rest of the Q45 Brain Trust.
Mud? In the injectors? BG Fuel Rail Flush immediately.oovmiester25 wrote:I did take the fuel rail out and remove the injectors because there was like mud inside. I took each injector out and cleaned the rail and checked the o rings on the injectors wich all looked like they were new. The wires that go to injectors look like they are different because they have been clipped and joined together with new ones using blue butt crimp connectors.
Exactly. It'll save you from a massive headache.Q45tech wrote:Why not acquire a brand new harness and avoid the possibility of intermitents in the splices and connectors?
http://www.nicoclub.com/FSM/Q45/oovmiester25 wrote:The diagram that I need is for the eight different connectors and wich injector they are connected to!
