Postby
silk240 »
https://forums.nicoclub.com/silk240-u50922.htmlThu May 01, 2008 5:18 pm
will the z32 front rotors fit with the J30 fornt brake caliper upgrade? i think the z32 rotors are 3/4 of an inch larger than the stock J30 rotors but is that to much of a size differance?
Postby
IanS »
https://forums.nicoclub.com/ians-u23642.htmlThu May 01, 2008 5:39 pm
The diameter of the Z32 and J30 rotors is the same, but the Z rotor will be about 8 mm thicker, which will cause the caliper not to fit over the pads and the rotor.
Postby
silk240 »
https://forums.nicoclub.com/silk240-u50922.htmlThu May 01, 2008 6:20 pm
i thought the thickness was only about 2 or 3 mm. the z32 are 30mm and the J30 are 28mm. i've seen that stated in several places and 2 or 3mm is not enough to not work i believe.
