Rotary S14?
simmode1
Car: Red '95 S14
s14tan wrote:aww Did you miss me D?
Nope...
danielsan
Car: 1991 240sx coupe SE
H8tred wrote:
It's a 2.2, all rotarys are really double their assigned capacity. Damn it. Mazda decided that since it's not technically a 4 stroke engine, that they could get away with measuring it by 2 stroke standards.
Don't believe me, look up any NA 13Bs factory numbers, and look at any other 1.3, then look at say a 2.6 Caviler. I rest my case.
i know this. if you notice sometimes the displacement has a x2 after it. mostly this is shown on some video games and some spec sheets. but its advertised as a 1.1 for the 12a.
spooled240
Car: kouki s14
true, that's why rotaries drink so much gas like any other 2 stroke engines cuz the power stroke comes on more often.
Sabot wrote:Blah,blah,blah, SR blah,blah,blah,it will blow up,blah,blah,blah,why ,blah,blah,blah,my SR don't run but I will never put a perfectly running rotary,blah,blah I don't know what I'm talking about only what I read,blah,blah,blah, RB25,blah,blah,blah,RB 26,blah,blah,blah, nobody know how to work with them,blah,blah,blah, and on and on and on..........in a land far, far away...........LOL
but very true
and I don't care if they can't go 200,000miles w/out maintenance, ROTARIES ARE THE SHIIT
S13Joe
Car: 92 Coupe
rotaries are the ****, if i didnt love 240s so much i would definatly be driving a 2nd gen. and for not being reliable? there has been rotaries with over 350,000 miles on them with just standard maintenance and of course not beating the living piss out of it.
White Comet
Car: fc, s13 and mazda6, Sierra
^ exactly. i dailyed my fc the 45 minute trip (one way) to school and back every day for 2.5 years. it didn't do good on gas, but the only reliability problem i had was a leaky injector, but thats nothing. even when it would flood, the series 5 is smart enough to unflood itself
H8tred
No, I can't say that I've ever noticed that. If Mazda was responsible for putting the x2 in print, I would hate them a little less (I don't hate the Wankel, I hate Mazda for their abuse).
spooled240 wrote:
true, that's why rotaries drink so much gas like any other 2 stroke engines cuz the power stroke comes on more often.and I don't care if they can't go 200,000miles w/out maintenance, ROTARIES ARE THE SHIIT
That makes no sense. 2 strokes get great mileage, and the powerband is up high. It gets there quicker due to a reed valve or simplified pressure operated pop-it valve, rather than a cam driven mechanical valve. That's about the only similarity between a 2 stroke and Wankel.It consumes fuel around the same rate as any other 2.6L.
As far as reliability, I have only seen a hand full of 13bs make it past 150k, but that is absolutely no fault of the engine. It's the dumb *** owners abusing them. They are known for their weak apex seals. However, if driven like you actually care about the car, you should never have a problem with the stock ones unless introducing forced induction, or higher levels of boost.
There's a reason a large number of light aircraft use the Wankel.
spooled240
Car: kouki s14
H8tred wrote:That makes no sense. 2 strokes get great mileage, and the powerband is up high. It gets there quicker due to a reed valve or simplified pressure operated pop-it valve, rather than a cam driven mechanical valve. That's about the only similarity between a 2 stroke and Wankel.It consumes fuel around the same rate as any other 2.6L.
2 stroke dirt bikes use a lot of gas compared to the 4 stroke ones, but 2 strokes are more efficient making way more power out of small displacement. So yes, you can say that a 2 stroke gets good mileage for their power but they still drink a decent amount of gas for their displacement. Theoretically, a 2 stroke engine will use twice the amount of gas for every intake stroke on a 4 stroke engine.
The wankel motor gets better mileage, but as far as the mazda rotories they aren't getting very impressive MPG ratings.
kornaz
Car: 95 240sx SE.
I like pistons. And i will stay with them. Something about turning triangles throws me off....
Ali 556
Car: '95 S14 Se....
lolololol,
so every on likes the "400whp @13psi" blown engine....FYI An LS1 + T76 Made 560whp @ 8PSI And 783Whp @14PSI...
All on 95 oct Fuel....
Also A 427ci (7.0L) LSx Made 2800 Whp @35 PSI (Drag custome made engine)....With TWIN GT47-88s
Who's laughin now bitcxh?
S13Teddy
Car: R32 Skyline, S13
White Comet wrote:^ exactly. i dailyed my fc the 45 minute trip (one way) to school and back every day for 2.5 years. it didn't do good on gas, but the only reliability problem i had was a leaky injector, but thats nothing. even when it would flood, the series 5 is smart enough to unflood itself
It's true, rotary powered cars seem to be very reliable, as opposed to what some say. Everytime I go to the track, it's the SR / RB / KA powered 240s that end up breaking down, and the FCs always drive home. Sure, sometimes the FCs will break something stupid like an axle, but it's never a major engine problem, whereas I've noticed lately that a lot of 240s at the track have been having major problems like rod knock, overheating, or burning ECUs.
White Comet
of course, it was rotary power that won 24 hours of le mans in 91, they can take a beating
Ali 556
Car: '95 S14 Se....
White Comet wrote:of course, it was rotary power that won 24 hours of le mans in 91, they can take a beating
Then immediately below...he even didn't run the "cooling Lab" why....b/c he didn't want it to blow on the track....@ mazda's booth....BOOOOOM rotary
grammar owns me
Ali
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
So true! N/A rotaries are unbelievably reliable for racing. Gotta build em' right, but that's the same story with any race-ready motor.
LeroyBrown
Car: 1995 nissan 240sx s14 blacktop
kornaz wrote:I like pistons. And i will stay with them. Something about turning triangles throws me off....
Sabot
Ali 556 wrote:lolololol,
TRAITOOOOORRRRRR!!!!!!!!!!!!!!.........LOL....small engines..small engines
White Comet
i loved my NA, the only reason i'm not driving it anymore is i pulled the na motor and sold it for $800. it'll get a 13bt eventually but i'm working on the s13 now
Bumnah
Car: 1992 240SX, black. Bone stock.
I'll keep my SR. Tanks though.
It's a cool project I suppose.
simmode1
Car: Red '95 S14
Oh c'mon! Thats like comparing apples to... really big f**king apples! Of course that would be expected from an ls1 with it's higher displacement. But you can't deny that those kind of numbers from a small displacement motor is quite impressive (if you can keep it running, that is..).
BTW, I'm not really a fan of this swap. I'm just commenting...
