Rota P45R for S13 coupe
Dammitboy
Car: 92' Nissan 240
Looking good ese. I've got spacers on standby if any fitment issues arise.
DoomSprayer
Car: R32 GTS-T
I test fit a stagger of 18/17 and the 18s look way better imo, they are much more aggresive
Dammitboy
Car: 92' Nissan 240
Well, I finally got them on. I think they fit really well & this is w/o spacers.
simmode1
Car: Red '95 S14
Nice job! Alot of ppl owe you for having taking the plunge into somewhat new territory. I honestly didn't think that +25 would fit up front! Kudos!
Dammitboy
Car: 92' Nissan 240
Thanks! I'ts a close fit, but it does fit fine. I would like to go lower, so I need to tweak the suspension a bit.
AZ89two4Tsx
Nice! How do you like the Sumitomos? I hear they're a good bang for the buck.
raptor727
do u know if that same set up will fit a spring strut combo?
simmode1
Car: Red '95 S14
Usually strut/spring combos have more clearance than coils...
raptor727
i have the same wheels, i have a strut spring combo with a 2 inch drop17x9 +25 im looking for what size tire will fit with out rubbing
disrupt
Car: 2006 TRD Tacoma, 1992 240sx coupe
great looking setup!
Just want to be clear, you are running 255/40/r17 all round, 9 inch +25 in the front and 9.5 +30 in the rear. Did you have to roll or pull your fenders/quarters? Have you noticed any rubbing while driving or cornering?
I hope my setup will fit this good, only time will tell.
Please add your setup to the fitment guide if you have not.
Again, great looking setup.
koukicody
Car: 93 Mazda Miata
whats up with your front wheel? looks like positive camber or messed up toe or something...
Dammitboy
Car: 92' Nissan 240
The sumitomos are decent tires, no complaints yet.
255/40/17 are in the rear
215/45/17 in front for now
Slight roll to the rear, I probably will roll f/r more later, as I'd like to go lower.
As for the front wheels looking off kilter, they're just turned in alittle.
RCCC_DRiFteR
Car: '89 Nissan 240sx
any rubbing issue at full lock Dammitboy??
Dammitboy
Car: 92' Nissan 240
Yes, a little, but not too bad. That will probably change when I go to a wider front tire.
RCCC_DRiFteR
do you have all your front fender ish all pounded in??
Dammitboy
Car: 92' Nissan 240
Not yet, but I will soon- I'd like to a little lower.
RCCC_DRiFteR
Yeah my coupe is slammed on steelies right now so I wanna sit low as hell on those Rotas. Should I post a pic lol??
Dammitboy
Car: 92' Nissan 240
go for eeeet!
simmode1
Car: Red '95 S14
Dammitboy wrote:go for eeeet!
For real. I don't care how many ppl get these wheels. They can't ever get played out to me... They are the perfect 240 wheel, IMO. They even come in better sizes and more concavity than LMGT4's while wieghing just a pound or so more...
Dammitboy
Car: 92' Nissan 240
simmode, did you ever get a set?
simmode1
Car: Red '95 S14
F***** No... My girlfriend is crazy expensive...
RCCC_DRiFteR
I just got fired 2 days ago so that's definitely putting a hold on me getting rims now My car...zerothread?id=433551
240tunerguy
Car: s13
biggie wrote:No, 4x114.3 17x9 +12, just came out.
I didn't get a chance to weigh mine. Would guess they are close to 19-20lbs.
Pics on my coupe, ignore bad fender pull, I suck.
your running 17x9 +12 all the way around with 235/45/17 with no rubbing? i know you said it before but after driving you can tell if it rubs. just making sure cause i love these wheels in that offset and making sure they fit nicely. thanks in advance!
