I figured it's about time for me to put my worthless $.02 into this thread.
Nothing wrong with running a T2 turbine on the KA. It is not the best idea for a track car, but definitely do-able for a daily that may see a few spirited runs.And as said before, it's not recommended for anything over 'X' amount of power, but it's fine for a low boost setup that's reliable and fun to drive on the street.With 'recommended' being the key word, you could be like me and Sunny and go against the grain...
I personally got the 'custom' made T2 turbine option for the GT3076R. I got the .86ar turbine and it's been machined out as large as it can be to fit the much larger than 'stock' T25 exhaust wheel.
Compare that picture with this one below. This is my old GT2860RS with the same .86ar turbine housing.
Now, that's not really an argument since most will say 'its the T2 flange that chokes out the motor.Very true in the fact that ANY and ALL gas has to go through that flange. Whether it's being given to the turbine to spool the turbo, or to be wasted out the internal wastegate. Large amounts of pressure build up in the manifold/header and you get lots of gas reversion in the cylinders.
This, for me, was remedied by welding on an external wastegate to my manifold. It's at the back of the collector so that the first two cyliders fire directly at the port which I had hoped in making it more efficient.
The wastegate source tube was TIG welded, but I was in a rush to get it done, so the exhaust/outlet side of the wastegate was MIG/Flux cored. Ugly, indeed.And the intake setup was temporary in that pic since I wanted to drive it before the sun went down.
With that all said, one can now put into perspective that the only gas that goes through the T2 flange is going to spool the turbo. No more backpressure to be had in the manifold. It's now wasted with the intended external wastegate.
I haven't run into any issues with the setup other than my engine bay is now cluttered, and looks like poo'. I still have power steering and the A/C works beautifully. I'm still not sure on the spool of the thing. I wanna say I get 10psi around 2800rpm or so.
I just totally lost track of where I was going with all this. I hope this helps clear a little bit up for you guys.I run 740cc injectors, Z32 MAF, self chipped and tuned ECU. I'm guessing by my trap speeds and weight of car I'm just over 400whp at 19ish PSI. Never been to a dyno. But my ET's and weight suggest about 350-360whp.
Here are some track video's for fun. Best ET was a 12.2 at 119mph but it's not on video. But you get the idea.Post up some thoughts or concerns. I'm the T2 guru for the most part. I love them. Particularly because my motor is only built for 500hp and I don't want to put a 35R on it and be tempted by the boost bug and pop her. lol
Enjoy girls and boys.
http://www.youtube.com/user/eazye4you
