Roller rockers on a S13 SR20DET?
X-MAN510
Car: SR powered 180sx aka "Boostin-Star"
Now can you run roller rockers on a S13 Sr20DET? I was helping a friend work on a K20 head and the thought just popped in my head can you run roller rockers on a SR, I would appreciate it if someone could answer my question.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Here's the only thing I've ever seen discussed on the boards about roller rockers
zerothread?id=323677
Nobody makes an aftermarket solution for them
corey240
Car: 1993 Nissan 240SX Base Drift Machine
I was told sr20der cams work in dets. There is a writeup on sr20forum about a guy that swapped roller rockers from a newer de into an older de. Im pondering the idea if its posible to do from the fwd new de to the det.
X-MAN510
Ya I saw that thread, thats why I thought it would be appropriate to post this thread.... thanks for the info I appreciate the quick feed back
X-MAN510
corey240 wrote:I was told sr20der cams work in dets. There is a writeup on sr20forum about a guy that swapped roller rockers from a newer de into an older de. Im pondering the idea if its posible to do from the fwd new de to the det.
Ya I was hoping I would be able to use my 272's with maybe the sentra rollers...
