Rolled the 240 onto the dyno today.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
With a big nudge from my friends lol. Did a lot better than I thought I was going to do so the car gets to live a long life. Was going to sell it if getting to 400hp proved to be just way too much work.
Here is a quick vid I took. http://www.youtube.com/watch?v=-9GswiaGa_M
Still trying to figure out my nistune vs the Lightning maf and big a** injectors lol
Didn't get to take it out to 7800 since it starts to lean out up top and I couldn't make any corrections to the map it's a start.
Carryl
Nice numbers man, what octane gas?
Monogato
Car: 1989 Nissan 240SX SE
Holy crap that's what I would like to see with mine...what mods ya got?
Yellow4g63
Thanks Carryl.
Mods are Tomie valve spring, Tomie 270cams, Supra TT fuel pump, Tomie head gasket, Protech-Fabrication exhaust manifold, Tail 40mm gate, SC61, Griffen Front mount, Nistune type 2 board, Sard 800cc injectors, Ford lightning Maf setup blow through.
RustspecS13
Car: '74 260z and '88 300zx turbo
Nice numbers, can't wait to see it when you can rev it out. How much more were you going to rev it, thanks to SAU I'm paranoid about my oil pump blowing up.
Does your car sound like that in person, it barely sounds like a RB20 on the camera.
~Alex
Yellow4g63
RustspecS13 wrote:Nice numbers, can't wait to see it when you can rev it out. How much more were you going to rev it, thanks to SAU I'm paranoid about my oil pump blowing up.
~Alex
Your not the only one lol. I want to rev to 8300-8500 but I wont I'd prob kill my oil pump gear. so 7800 it will be, it's just loud because it's open down pipe since I didn't really plan on been on the dyno.
eh?
Nice numbers Seems like you could have picked up a lot of hp if you rev'd it more. I've rev'd my RB25 to 8400 with no damage to the gear. Just try not to hit the rev limiter. How much timing are you running up top?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Nice!!!! Inspiration for me to work on my car.
Cjmartz2k
Car: Hunting for a '89 GTR now
Wow, that's awesome, especially for a RB20! You've got SO much more in it looking at that fuel curve, and considering most widebands won't read any richer than 10:1.
DriftingisLame
Car: '91 240sx coupe, rb20det
Dude, I'm so proud of you. You've been on this forum ever since I've been here, and I dont think I've ever seen your car run!
This is great news! And wow there's so much potential, this is a good start though!
Congrats!
Carryl
I've been revving mine to 8500 for the last 2 ~ 3 years.
Yellow4g63
eh? wrote:Nice numbers Seems like you could have picked up a lot of hp if you rev'd it more. I've rev'd my RB25 to 8400 with no damage to the gear. Just try not to hit the rev limiter. How much timing are you running up top?
I really didn't change the factory map much at all. I added 2 degrees to the top for a total of what looks like 22 deg at that part of the map.
Yellow4g63
DriftingisLame wrote:Dude, I'm so proud of you. You've been on this forum ever since I've been here, and I dont think I've ever seen your car run!
Congrats!
I didn't think I would have it running either lol it's mostly my friends at the shop if it wasn't for them I prob wouldn't even have it running right now.
Carl H
lookin good man...i did a similar power pull.
4 years ago, lol!congrats tho, glad to see it finally running.cams will change the way the engine sounds, coupled with aftermarket intake manifold and exhaust manifold highly modded rb20s sound nothing like stock.
flatrate
Car: S14 kouki
I need to get my s*** in gear and get on the dyno!
WhatsADSM
Car: 1998 240sx
Great numbers. Nice to see someone put down good numbers on the 20.
How much boost were you running?
Also definately get the fueling figured out, as you are starting to get awefully lean up top there!
Yellow4g63
WhatsADSM wrote:Great numbers. Nice to see someone put down good numbers on the 20.
16.8 on the 398 he let off as soon as it started to go lean, the revlimiter is at 7800 and the 395 is on 18psi but letting off early. The ecu was unresponsive to any of my commands blows the stock ecu seems way harder than a stand alone ecu lol.
matthunter1448
Car: 1995 240sx with rb25det
compressor surge much?
meet07
Car: 89 180sx rb25det
Why didnt you crank her up to 21psi??? And thanks to you I too will be doing nistune with the blow through ford lightining MAF.....
sounds good!!
Yellow4g63
meet07 wrote:Why didnt you crank her up to 21psi??? And thanks to you I too will be doing nistune with the blow through ford lightining MAF.....
sounds good!!
couldn't get control of the map to safely go past the 18psi. Had to stop the pull because it started to lean out near the top. I'm almost at my HP goal for this whole project which is 400whp, until I start working again and can afford to rebuild the motor with forged slugs.
matthunter1448 wrote:compressor surge much?
Is that what it was would have never known. Thanks for the info champ.
jdmser
Car: duh
Nistune works well with the big injectors and the Lightening maf? You have any idea what the maf voltage was at peak hp. I was talking to a guy that tunes Mustangs and he was saying that the Lightening maf peaks about the same as the z32.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
i had a similar problem with my engine leaning out in the upper RPM range and what i found is my fuel pump wasnt able to sustain the voltage needed to keep the flow up...just out of curiosity did you happen to correct that for an upgraded pump like the denso your running...the reason i ask is im running the exact same pump, and when i resolved the fuel pump power problem...i actually had to go and have it retuned becuase it was throwing too much fuel ...lol
WhatsADSM
Car: 1998 240sx
OP if you are commanding more IDC but your AFRS stay the same then u are likely leaning out due to supply. You may want to rewire your pump and if it is a walbro I would not be the least bit surprised if you replace it and your supply issues go away. I have seen quite a few walbro's that don't just die but instead begin to not flow as much as they should.
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
great job andy...its def come a long way...now u need a real management system and you could me makin so much more HP
StricNyne
dayumn man... i have nothing to say but WOW!!!!! 400 whew.... now we need to talk about getting our RB Meet and BBQ going...
Yellow4g63
S14-NEO wrote:i had a similar problem with my engine leaning out in the upper RPM range and what i found is my fuel pump wasnt able to sustain the voltage needed to keep the flow up...just out of curiosity did you happen to correct that for an upgraded pump like the denso your running...the reason i ask is im running the exact same pump, and when i resolved the fuel pump power problem...i actually had to go and have it retuned becuase it was throwing too much fuel ...lol
It's running off the stock power right now. I have the relay kit to hard wire it just didn't get around to doing it yet. Will be doing it and a few other things next time I drive down there.
Yellow4g63
jdmser wrote:Nistune works well with the big injectors and the Lightening maf? You have any idea what the maf voltage was at peak hp. I was talking to a guy that tunes Mustangs and he was saying that the Lightening maf peaks about the same as the z32.
Didn't log any of the pulls I will next time and let you know the voltage I'm hitting.
Yellow4g63
WhatsADSM wrote:OP if you are commanding more IDC but your AFRS stay the same then u are likely leaning out due to supply. You may want to rewire your pump and if it is a walbro I would not be the least bit surprised if you replace it and your supply issues go away. I have seen quite a few walbro's that don't just die but instead begin to not flow as much as they should.
It's a Denso Supra TT fuel pump. Suppose to be 280lph and 310lph hard wired. I don't trust Walbro's lol prob from my days with when I had my DSM.
Yellow4g63
toadx8u wrote:great job andy...its def come a long way...now u need a real management system and you could me makin so much more HP
Prob might be next if I can't wrangle in the Stock ecu .
meet07
didnt know the factory pump flows more than the walbro??
