Rolled the 240 onto the dyno today.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Yeah but it's no where as cheap as the Walbro so not too many people go for them. You can get a walbro for $90-100 but the supra pump is usually $170-220 depending on where you find it.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
glad to see it putting down!
Chaos the Xile
Car: 1974 Datsun 260Z
GAWD! Those Cams make your engine sound soooo aggressive! Fixs those maps I know its got more power leerking in there some where!
meet07
Car: 89 180sx rb25det
toadx8u wrote:great job andy...its def come a long way...now u need a real management system and you could me makin so much more HP
Why would he need to upgrade the computer?? will it not support 500-600+ whp??
Yellow4g63
Stand alone's usually have a 24X24 or bigger map to work with so you have way better resolution vs the stock 16x16 map. What size injectors are you going to run Meet07?
meet07
I want 700-800cc's since I can get my hands on some local e85...
but wee will see what the budget look like next month. But ill be ordering my nistune for sure in about 2 weeks. Ill be doing the blow through as well...
you said get the 01+ lightning maf right??
Sil240
Car: Nissan S13 "The One Cam Wonder"
I can't wait till you get your ECU Tuning down
Carl is Tuning my ecu, I'm hoping to hit #s like yours.Soon there will be a hand full of big power 20's running around the US
Yellow4g63
meet07 wrote:I want 700-800cc's since I can get my hands on some local e85...
Yeah it's 01+ Lightning maf the 90mm version. I wish I could get more time to mess with the car but it's stored 56miles from where I live lol, and I have another car that I have been working on so it's not help.
savanna13
Car: Turbo GS3
I would be shifting at 7k till I got some more gas up top. Then rev and rev!
Yellow4g63
savanna13 wrote:I would be shifting at 7k till I got some more gas up top. Then rev and rev!
Don't worry all it's doing is idling and moving forward and backwards at the shop since I'm playing with different bin files to get it right.
meet07
What kinda trouble are you having??
Yellow4g63
The setup of the bin file. I couldn't figure out how to setup the latency for the new injectors.
meet07
Yellow4g63 wrote:The setup of the bin file. I couldn't figure out how to setup the latency for the new injectors.
I did a quick search and found this: http://forums.nasioc.com/forum...92990
Im not sure how much good it will do you but I figured it may help ya. I need to read more up on Latency myself.
Are sard injectors made by JECS?? Nistune states that if so you shouldnt have to mess with it.
Check out this link too: http://injector-rehab.com/kbse/lag.htm
hope this helps cause im sure ill need ur help when its time..
Yellow4g63
Sards = denso injectors. I thought the same thing but let me tell you they are wrong lol. I didn't set the latency last time and couldn't control my fuel map. Still playing it the bin setup, I think I got it this time tho won't know till I go back onto the dyno. The Kconstant calculations were way off, so much so the car wouldn't run at all until I adjusted it. Save yourself some trouble and talk to CarlH about a base bin to get you started, then u tune the fuel and ignition yourself.
meet07
If I cant figure it out I will def hit him up...What about the lightning maf voltage? did you have to modify it?? And if so how do you go about doing so?
